1996 chev 1500 4.3 W/T Experts Take a whack at this one
    96k has shift indicator light go out, speedo doesn't work, won't shift, tach not working. abs light came on and check engine light and check guages light. any ideas?
    well if the trans doesnt have a vss signal it wont shift.
    sounds like a computer problem or a fuse or a broken wire somewhere
      That many things localized like that, I would want to say fuse as well.
      • octanehuffer
        • 5265
        Fuse or missing power to instrument cluster ckt. I have seen this when change from the ashtray falls into the cig lighter port.
          All fuses are good checked the ignition switch. Thinking it might very well be the pcm. All this started in one shebang. Every fuse is getting 13.5 some 13.9 almost forgot it will shift via solus scanner.
            if ALL the fuses are good id say pcm just for the simple fact you have no vss signal
            no vss= no shifty.
            could be a bad connection somewhere also,, go around and wiggle wires and stuff. check connnections to pcm
              Tried pcm no luck. When I unplug the tranny the tach comes back. Annoying damn thing. Going balder if it was my truck get the torch!
              • 88mark8
                • 344
                Ground issue.
                  Did a check on all the wiring its getting power the tranny just won't shift checked all the fuses still no tach unless the harness is unplugged from the tranny. Tried changing the fuses around being a real head scratcher.
                  • xjfish
                    siiiiiiick!
                    • 7357
                    Originally posted by 88mark8 View Post
                    Ground issue.
                    I concur.
                    1987 Oldsmobile Cutlass Ciera
                      I figured it out.. its the cross thing on the front and back. Checked the entire harness and plugs no luck. I haven't found a broken or bad ground wire yet I have cleaned all I have found via the wiring schematic. Full day wasted. Has to be a relay or sensor or some damn thing.
                        cross thing?
                        • 95 whitestang
                          • 3601
                          So is everything else fine with the transmission unplugged? Its possible the problem could be a pinched wire in the transmission itself.
                          Originally posted by mnstang
                          Originally posted by 2 beer
                            How is that a day wasted? You so far know what its not, now you are closer to narrowing down what it is. Keep on keeping on, but remember, time spent isn't necessarily time wasted.
                            • octanehuffer
                              • 5265
                              The cross thing= bowtie
