1984 Mustang Redemption
  • MadJack
    • Jan 2010
    • 2776
    This is mostly a Redemption build.
    The car has a weird paint job, janky interior and hacked in EFI from a 94/95 gt, including the trans.
    First step is take care of the mechanical.
    Pulled out all the efi wiring and intakes.
    Picked up a proform intake,600cfm edelbrock carb and stock 1984 distributor.
    Picked up a c4 trans, torque converter and flex plate.
    Also almost everything i need to swap to 5 lug/4 wheel disc.
    Got some nice FR500 18" rims.
    Test fit
    Before
  • MadJack
    • Jan 2010
    • 2776
    After
    • forgotn
      FIREMAN
      • Aug 2008
      • 2666
      Looks like the body is pretty solid. Underneath good also?
      I have a PORNOGRAPHIC memory
        Those flames tho
          Those flames tho
          They look backwards?
            • Turbo302
              Impossible is only Underfunded
              • 1528
              If the motor is stock from an 94-95, your gonna have problems with an 84 distributor. Was the efi not running well? Why remove?
              1988 5.0 Notchback
              100% Stock 302 Intake to Oil Pan as delivered from FORD Factory
              100% Stock Driveline (T5, Clutch, 3.08's, control arms etc...)
              100% Stock ECM/Tune ('88 California Mass air ECM)
              1 bolt on... Baby Precision TE44 TURBO
              Best time to date: 11.562 @ 123.37 1.892 60-ft BIR 9/19/08
                It matches the directional tire that is on backwards
                Originally posted by MadJack View Post
                Test fit
                [ATTACH=CONFIG]22896[/ATTACH]
                  What about the ranger and the van?
                    • blown 87gt
                      Professionaly Charged GT
                      • 2833
                      You must have a fetish for cars with gaudy flames.
                      • MadJack
                        • Jan 2010
                        • 2776
                        Its rust free! Cars originally from Arkansas.
                        • MadJack
                          • Jan 2010
                          • 2776
                          The gear was changed on the dist.
                          The efi was running bad, did a tune up and this and that with no luck, and it was hacked in pretty bad. Gonna get a wiring harness this weekend to replace what was hacked.
                            lol
                            • MadJack
                              • Jan 2010
                              • 2776
                              Pulled the dash lastnight, and yanked the rest of the hacked up wiring from the engine bay.Click image for larger version
