***Note: doing a copy/paste from my build log to post here***
I bought this truck in October of 2011 with 22k on the clock. This is my 5th pickup, 3rd f150. It is an XLT with 5.4, 4x4, and not much else.
Detail guy did a shittty job, much of the clear was micromarred, as you can see on the wheels, he doesn't know anything about tire cleaner. The windows where also terrible. They offered to clean it up, I told them if they touch it anymore I won't take it
I took it home and did a quick detail using clay and all my goodies..
The end result is MUCH better...Not a fan of the chrome though...
I decided it was time to dump the hard bed cover and also the 4x4 stickers, these just don't look like they are quite at home here...
This looks MUCH better!
I also had some plans for it over the weekend...
Before:
After:
I gave it a 2" drop using drop shackles. I chose to drop/level the back as there is not a lot of clearance in my garage. While I don't mind tastefully lifted trucks, I don't like to get in and out of them... I also took some VHT to the tail lights...
I also wanted some auxiliary/reverse lights.
The lights I used: http://www.maxxima.com/products/prod...ght/view/.html
I wired them off of the 7 pin towing harness to get the reverse as well as constant/switched power. Even though the draw was about .5 amp, I still put in a relay.
The relay is mounted behind the rear driver's side tail light. Wire was ran to the cab and a switch installed under the headlight switch. When flipped towards R, reverse only, in the middle, nothing, to the left, auxiliary lights. With how it is wired the lights will not be on unless the key is on so there is no "whoops" and forget to turn them off.
Here is a shitty pic from the other night. I need to mod them so I can swivel them out to the sides a little bit more and tighten the mounting screws
Before:
After:
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
There are 3 small dimples, going to talk to a local body shop that does PDR and see what they want to take care of that, hope they can...if you don't know the dimples are there, you don't see them...
.jpg)
