Clay bar? liquid clay bar?
    anyone familiar with this stuff? ive heard it works great i bought the liquid stuff but am too much of a puss to use it after i read the instructions.....at the end it says to use some polish, which leads me to believe that it works like a rubbing compound. --so being a novice i don't wanna end up with a dull finish that i cant fix...
  • VELOCITY
    Pacer's RULE!!!
    • 2900
    I've used a regular clay bar, not the liquid stuff though. With the regular clay bar it's really hard to mess up the finish unless you drop the clay bar on the ground and pick up some sand and grind it into the finish.
      Stick with clay bar it works way better, i have some if you want to try it out before you buy
        sweet--does it bring the finish back? the paint doesn't shine as much as i think it should
        its for my denali XL, how many do u think id need to do the truck? ...or should i think about a different approach? i'm just really apprehensive about using any kind of abrasive shit on it--thanks for the info guys
        • Hotstang
          Ya Trick Ya
          • 4196
          I have alot of experience using the real clay bars, never used the liquid stuff. Its hard to mess it up, just use clean rags and use plenty of quick detailer to lubricate the clay.
          If the paint is dulling on your vehicle, the clay wont make the paint shine again, but it removes the particles that are embedded on your paint and will make polishing and waxing much easier and more effective. Your paint will shine better, with less effort in the end.
            what will restore the paint? its an 02 denali... its not like the paint is junk or anything
              You should buff it out but clay it first you will be amazed
              • Phillyblunt474
                • 5275
                Clay it then buff it.
                • bullittstang
                  MECP FTW
                  • 254
                  quick detailer is ftl. just use new carwash soap+water, works awesome.
                  Representin up North!
                  • Hotstang
                    Ya Trick Ya
                    • 4196
                    3 step polish, an orbital buffer (with foam pads, if a n00b) and time. Will look like new again in a half-days work.
                    • Drop Top
                      Slow is MY WAY of LIFE!!!
                      • Jul 2007
                      • 7691
                      clay bar made my fobra really smooth and it looked great..
                      Originally posted by sinSStr
                      Jesus Christ. Only on TCS does a tips thread turn into an argument.
                      but having a 4v motor makes it a cobra
                      • NAZISALEEN
                        Afro Samurai
                        • 12235
                        Clay bars were developed for removing rail dust from paint. A common problem with white/light colored cars. Basically when transported by rail the metal on metal of wheels and track make a dust of steel slivers that stick in the paint. After time they would form small rust rings in the paint (rust specs) It is also used now to remove contamination not able to be seen by the human eye and over spray.
                        Nothing works as well a high speed buffer and multi step polish for bringing back a finish.
                        • speedster1322
                          • Jul 2007
                          • 11
                          Suggestion - Go to Meguairs On line forum. There is alot of info on the how to's of using a clay bar. Over all what it is supposed to do is remove blemishes in the paint. You do have to follow up with polishing and waxing.
                          Steve
                          SCOA State Rep
                          06 Triple Black SC Speedster 1322
                          • Zippy
                            Fast stuff is cool
                            • 2139
                            Looks like you have a pretty sweet car. We'll probably have to run 'em.
                            • 351capri
                              64 fairlane someday
                              • 14584
                              If your gonna use a buffing compound, i have had good luck with this on my truck
                              This is the less aggressive compound.
