tire size conversion
  • orangefox
    • 1603
    What size slick would be about the same as a 315/60/15?
    2002 Ford Excursion
    2003 Ford Expedition
    2005 Mercury Mariner
    80' Buick Regal drag car
    88' LX Mustang 5.0
    2010 Yamaha Road Star
  • tirenick
    Pimp of Tires
    • 6255
    30x13.50-15
    • orangefox
      • 1603
      Thank you!
      2002 Ford Excursion
      88' LX Mustang 5.0
      • tirenick
        Pimp of Tires
        • 6255
        Thank you!
        • KrisR
          KNT-SHO
          • 12737
          Originally posted by tirenick View Post
          30x13.50-15
          Not to be argumentatatatative, but wouldn't a smaller slick be closer, since the slick's 'width' is the actual tread width, and the radial's 'width' is the sidewall width?
          M/T says their 315/60-15 is 30" dia, 12.9" sidewall width, and 11.9" tread width. Their 29.5x11.5-15 is pretty close overall, at 29.9" diameter, 11.1" tread, and 13.6" sidewall. Also, the slick will obviously grow more than the drag radial, so it will be taller at the big end.
          Just some things to consider.
          • tirenick
            Pimp of Tires
            • 6255
            Yes you are correct.....I was refering to the overall dimensions of the 315/60-15 as being 30x13.50-15. The actual "slick size" closest to that would be the 29.5x11.5-15....you sir are right!!!! SORRY
            • orangefox
              • 1603
              Interesting
              2002 Ford Excursion
              88' LX Mustang 5.0
              • orangefox
                • 1603
                So should you screw in the tires if you don't use tubes?
                2002 Ford Excursion
                88' LX Mustang 5.0
                • tirenick
                  Pimp of Tires
                  • 6255
                  I haven't on any of ours. Most of the ones we have done tubeless have been unscrewed as well...
                  • orangefox
                    • 1603
                    So what size rim do you think I have then with that size tire?
                    2002 Ford Excursion
                    88' LX Mustang 5.0
                      If you dont tube your slicks they will get low or go flat every week,they are pouris.(sp).
                      Tube um.
                      • tirenick
                        Pimp of Tires
                        • 6255
                        prolly 10" would be the best
                        • tirenick
                          Pimp of Tires
                          • 6255
                          Tube um.
                          zip it LES!!!
                          • orangefox
                            • 1603
                            I got the tires today, I got the 29.5x11.5-15. When I measured them they are 2 inches taller than the ones I got now and I don't know if they will fit now. You were not the only one I asked either and they all gave the same dimesions saying that was the matching tire to what I have
                            2002 Ford Excursion
                            88' LX Mustang 5.0
                            • tirenick
                              Pimp of Tires
                              • 6255
                              what kind of tires?
