Wider tires for stock rims on stock height 2004 GT
  • Lukewarm
    • Apr 2010
    • 47
    Norm,
    What is the widest tire I can mount on the stock rims of a stock height 2004 Mustang GT?
    I want the same diameter so my speedo stays accurate. It currrently has 245-45-17 tires on the polished rims.
    Thanks.
    275/40r17 is the widest you should go on an 8 inch rim.
    • tirenick
      Pimp of Tires
      • 6255
      This! Same overall diameter bout 1 inch wider
      • Lukewarm
        • Apr 2010
        • 47
        Will 275-40-17s fit front and rear without rubbing through the full suspension travel and the entire steering arc?
        • tirenick
          Pimp of Tires
          • 6255
          • Lukewarm
            • Apr 2010
            • 47
            What would a front end alignment cost for the 04 Stang? The fronts seem to wear a little more on the outside edges and wider tires will probably make it worse.
            • tirenick
              Pimp of Tires
              • 6255
              $89.95
