MAP 2.4L Drag Evo 8 makes 1053whp on Stock ECU!
  • BURD
    • Sep 2007
    • 193
    After three separate 1-2 hour dyno sessions (customer cars come first and late night tuning is not looked upon kindly around here) we have reached a power level that we feel will be adequate as we continue our quest for an 8 second pass in our 3000lb street legal Evo 8. In the process we have set the bar pretty high for the stock ECU horsepower record I realize that some of the information below is identical to that of our previous post, but we simply cannot say enough about the stock ECU developers and our sponsors that made this a reality!
    Build Details
    MAP Stage 2 2.4L Shortblock
    - OEM 100mm Crankshaft
    - Wiseco HD Pistons
    - ACL Race Bearings
    - MAP Spec Howard's Rods (Standard length 150mm)
    MAP Stage 5 Cylinder Head
    GSC S3 Camshafts
    GSC Valve Springs & Retainers
    Fidanza Cam Gears
    Precision Turbo Billet 76mm Ball Bearing Turbocharger
    Speed Density with AEM 5 Bar (Special thanks to Scheides for all of your help!)
    Sparktech Coil on Plug
    AEM CDI Ignition Box / Wideband / Gauges
    ETS 5" Front Mount Intercooler
    Fuel Injector Clinic 2150cc Injectors (E98 Fuel)
    Magnus V5 Cast Intake Manifold & Fuel Rail
    OEM replacement parts supplied by mitsubishiparts.net
    QuarterMaster Twin Plate Clutch (2010 Revised Version)
    Torque Solution Motor Mounts
    Mishimoto Aluminum Radiator
    Turbosmart Raceport BOV / 45mm Wastegates / eBoost2 / AFPR
    Stock ECU Developers / Innovators
    As always we can't say enough about how thankful we are to the stock ECU gurus that made this a possibility. If I try to name all of you I will most certainly leave someone out unintentionally, so I hope that addressing the group as a whole will sufficiently convey our gratitude If ever there is anything we can do to further advance the capabilities of the stock ECU please don't hesitate to let us know!
    [SIZE="4"][CENTER]Click the image below for a larger view!
    Thank you to our sponsors, this wouldn't be possible without you!
    1960 Anglia Escort
    500hp neon SOLD
  • LS1Z28
    • 2392
    got vids?
    Oh heavens no I'm a big pussy, my parents sealed that when they named me Chet.
    • Chris-Supra
      Buicks > You
      • Mar 2005
      • 1992
      IB'NOLSXNOCARE'
      2005 Subaru WRX STi
      • slo306n/a
        What now
        • 889
        Originally posted by LS1Z28 View Post
        got vids?
        x2
        • LS1Z28
          • 2392
          Originally posted by Chris-Supra View Post
          IB'NOLSXNOCARE'
          I gotcher LSX.
            was she sitting on the dyno that night we stopped in to take the tour? :x
              that things gotta sound mental at 8500 rpm lol
              • wiplash
                2014 TT/GT
                • 3479
                Well, you can't pull the "low boost" card! Nice!
                -No one ever
                  • Scotty07
                    Meh
                    • 19655
                    Yeah, but the "it wouldn't hook" and the "I missed a shift" cards are still on the table.
                      AWD?
                      • octanehuffer
                        • 5265
                        Wondering how long it will stay together
                        • BURD
                          • Sep 2007
                          • 193
                          Nice thing about AWD and drag radials it is a bit easier to get traction. Oh and built trans and transfer case on the way with a ford rear end.
                          1960 Anglia Escort
                          500hp neon SOLD
                          • BURD
                            • Sep 2007
                            • 193
                            Similar motor to what is in our Rx-7 she will take a beating all season long.
                            See you guys on the streets.
                            1960 Anglia Escort
                            500hp neon SOLD
                            • octanehuffer
                              • 5265
