I know I'm a couple months premature
, but I couldn't resist working on the car on such a fine day. Even fired it up for the first time since November. Had to add a couple fittings to the coupler since I have two bypass valves instead of one and I have an oil line venting into it. Everything fits fine except the heat shield, which will require a little modification before I can bolt it on.
Here's to 499.99999 hp!!!!!!11
EDIT: here's the cute little factory Vortech piece.
Couple shitty vids.
, but I couldn't resist working on the car on such a fine day. Even fired it up for the first time since November. Had to add a couple fittings to the coupler since I have two bypass valves instead of one and I have an oil line venting into it. Everything fits fine except the heat shield, which will require a little modification before I can bolt it on. Here's to 499.99999 hp!!!!!!11
Couple shitty vids.
