Fox Mustang Engine Pulling Trick
  • flstci71
    More Ovaltine Please!
    • Jan 2007
    • 753
    If you want to know a shortcut for pulling your Fox Mustang motor, here's a trick for you - Just pull the grille/lights/bumper/radiator/condensor, zip off the upper radiator support with a Sawzall and the motor comes right out through the front. No need to lift it way up and over things. Easy, huh? No thanks necessary....
  • taank
    • 10278
    hacjk
    Jake H.
      I HS auto mechanics student who is failing could have a 5.0 out in the time it took you to do the above highlighted tasks.
      • merkurmike
        mare-coor
        • Apr 2008
        • 56
        im going to hope that the stang was well past saving or in the process of getting body work done.
          That is however the correct way for an Audi (except for the Sawzall part)
          • slo306n/a
            What now
            • 889
            I've done it!
            Upload Pics with PicTiger
              • v6mustang94
                V8? What's that?
                • 737
                Well if you're going to lift it, you might as well lift it "way" up instead of doing all that bs work...
                • 5-door
                  www.jtracecraft.com
                  • 5001
                  ZOMG! You cut a Mustang! You evil evil person! They're so rare! How could you do that?!
                  Good work. I like your style. You're good people.
                    ............... I dont know why you had to say that................. is it because.....your.......vagisil........isnt.....wor king?
                    /////,,,,,//////perhaps?
                    .........maybe
                    ////definately
                      /////////////..,./,/.,/.,/.,/.,/.,./,./,./,..../,./,.,,..,./,./,/.,;,[p';,/,/;,/,;,;,;/,/;,/
                      • 5-door
                        www.jtracecraft.com
                        • 5001
                        .........maybe
                        ////definately
                        Is Chop_Shop_Bob_T posting under your account?
                            • 5-door
                              www.jtracecraft.com
                              • 5001
                              Fail.
