Falcon Part IIIV
  • 64fairlane
    • Oct 2026
    Falcon Part IIIV
    Changed it again hopefully stay this way a while.
    Had to build headers again...
    Mounted control box in the glove box.
    Needs a little more and should be back on the road.
    Awesome as usual. Didn't know you were building headers already or I woulda stopped up.
      Getting pretty good at it banged them out in 6 hours... Just need to take them out disassemble, finish weld, paint and reinstall.
        Looks a lot better than the last set of longtubes we made
        • 5.0stang85
          Hater's be hatin'
          • 7065
          How close is that coil pack to the master cylinder?? looks mighty close..
          Cooter's Coatings
          Hudson WI
            Boot just touches. Shouldnt have a problem as its touching plastic.
              Only difference is i could get those out of the car not sure about these.
                How much for this Cooter fella to coat a set of headers?
                  Looks fine, why does it matter?
                    I figured you woulda mocked up one tube, pulled it out and welded it, mocked up another tube, etc.
                    Oh, and those headers are facing the wrong way
                      I still might do that but I still need to get them out.
                        Rubber boot+plastic tank= Explosion!
                            I topped off the reservoir with dielectric grease to avoid possible issues.
                            • 5.0stang85
                              Hater's be hatin'
                              • 7065
                              PM'd ya
                              Cooter's Coatings
                              Hudson WI
