So much want....
    So much want....
    1990 Ford Mustang LX Twin Turbo (Price Reduced)
    Motor Specs:
    363 cu. in. (302 based), 3.4 stroke forged crank, H beam rods, 4.125 bore CP pistons, 8.8 compression ratio, Dart 4 bolt block, Moroso pan/windage tray, FMS F303 hydraulic roller cam, 1.7 roller rockers, tie bar style roller lifters, ported Canfield aluminum heads, MLS head gaskets, Trick Flow R intake manifold, Incon TT800 twin turbo system intercooled, SFI harmonic balancer, Holley throttle body. Runs on premium pump gas (93 octane)
    Transmission:
    Performance Automatic Super Comp C4, reverse manual valve body, trans brake, deep aluminum pan, 10" PTC Comp converter, SFI bell housing, Hurst pistol grip shifter.
    Drivetrain:
    Mark Williams driveshaft and yoke.
    8.8 Ford rear end, Strange 31 spline axles, C clip eliminators, 3.55 gears, aluminum cover/girdle.
    Fuel System:
    255 L/hr pump, T-Rex pusher pump, 42 lb injectors, billet adjustable regulator, adjustable mass air
    Misc:
    200 amp alternator, rear mount battery, Ron Davis aluminum radiator, Hurst line lock, 17x9 polished Cobra R rims, 5 lug conversion, Tokico adjustable struts, strut brace, adjustable caster/camber plates, Intrax 2" lowering springs, subframe ties, adjustable rear lower control arms, South Side upper control arms, Nitto front tires, M/T drag radial rear tires. Anderson PMS piggy back computer.
    700 HP at 15 psi, 1/4 mile time 10.4 seconds at 127 mph on DOT tires. Over $40,000 invested.
    Bought in the late 90's with damage on the drivers front (salvage title) as an original Mustang with no modifications. Replaced fender, hood, door and windshield.
    Salvage title and an extremely lacking fuel system? No thanks.
      Yeah, pretty cool fox but that's a lot of money for a salvaged fox no matter what else.
        No shit.
          Nice looking interior.
            What an ugly pile.
            • Meegs
              AA for Mustangs
              • 3062
              700hp on pump gas with 42# squirters? Ok...
              I would not want to be the guy changing spark plugs on an Incon kit!!
              I think it's priced ok
              93 Teal Cobra #2531
              Turbo Cobra MAFIA
              1 of 452
                Pistol Grip
                  Originally posted by CleanLX View Post
                  What an ugly pile.
                  The 80's called.
                    Pistol Grip
                    Lame pistol grip.
                    Old school Hurst / Mopar were the 'real pistol' grips.
                      $40K invested. More like wasted. That's no investment.
                        his loss your gain
                          I've seen people spend 13k on a lot dumber shit
                            his loss your gain
