Another do want!
    Another do want!
    I've had this 86 Mustang GT for over ten years.
    This car is originally from North Carolina(title says so) and is a CLEAN car. Absolutely No Rust! Not even a little in common FOX body areas
    There's so much done, but I'll try to include it all.
    Engine built in 2006 with the following.
    SCAT 347 Stroker 10.5:1
    Comp Cams XE 274HR 112LSA .555/.565
    AFR 185 Heads
    1.6 Crane Roller Rockers
    Extrude Honed GT40 Lower
    Comp Cams Polymer Power Box Upper
    70mm Professional Products TB
    C & L Intake Elbow w/ 76mm MAF
    AmsOil Air filter in Fender Well
    MSD 6AL2 with 2Step rev limiter
    Northern Aluminum 2 Row Radiator with electric Taurus Fan
    BBK Long Tube Headers
    X Pipe
    SLP Loudmouth Cat Back 2012
    Super Duty T-5 Installed Spring 2012
    3.73 FRPP Gears
    Five Lug Conversion in 2008
    94-98 Rear axles and discs
    2000 PBR Dual Calipers Front Discs
    Rack and Pinion 2013
    FRPP "C" Lowering Springs
    Welded-IN Subframe connectors
    2003 AFS Cobra Rims w/ black windows
    17x9 Rear with 275/40R17
    17x8 Front with 245/45r17
    This car has 400hp I have the time slips to show that this car runs 12.5s @ 112 on the street tires installed. At that MPH with drag radials or slicks it could be in the high 11s. The suspension is set up more for handling so I'm sure it could be in the 11s. One ride and you'll know.
    Even with the stroker and HP I can drive it every day and wouldn't think twice about driving it across the country and get 24MPG.
    The odometer reads 58xxx and will go up as I still drive it.
    $8600 No trades either, except for an 03/04 Cobra or a 2005+ Mustang GT, and this car is much faster than those from the factory. Call or text 715 367-7837
    nothing special. the stance is all whammied, looks funny, plus shitty plenum box intake and other questionable parts. meh.
    • 94fobrah
      2012 RSN #3
      • 8820
      Junk
      90 LX 445CI N/A SBF
      Built By Dave Senderhauf JR
        I like it.
        • Exjay
          80085
          • 6637
          Seems just a tad high pricewise considering fhe time of year.
          "On this episode of roadkill"
            I like 86's. Wheels stick out too far and don't go with that car at all, wrong color, needs to be Light Regatta Blue and that comp polymer intake is junk. Headlight covers need to go back to the 80's
            • OhMannClint
              Hated by the DEViDOs'
              • 6149
              I like it alot
              Clint Ohmann
              651-399-9534
              High Pointe Realty
              ClintOhmann@gmail.com
                Saleen was a killer deal compared to that........
