lolz. overbuilt stuff.
  • SS1LE02
    By the way, which one's pink?
    • 4387
    2009 CTS-V
  • Iroc-Z
    Freeze, turkey!
    • 4993
    So they are replacing frames instead of welding them?
    Originally posted by xjfish
    • SDK
      #1McMoppoFan
      • 12342
      Thats crazy
      • Gipper
        George W. Randolph
        • 5228
        It's an Fj Cruiser, what do you expect?
        • Jeffescortlx
          Frum roll
          • 2003
          I was expecting some rust rot, but it it looks like a the metal just tore.
          • LS1Z28
            • 2392
            Good to know.
            Oh heavens no I'm a big pussy, my parents sealed that when they named me Chet.
              Broke right off at the edge of the weld
              I would guess that the frame is too thin at that point to support the motor. Perhaps some additional gusseting as well as not relying on such a small area as the only stress point would be a better plan
              OVERBUILT!!
              • Bmikkalson
                • 3333
                OVERBUILT!!
                You should write and tell Toyota.. You seem to have a grasp on this!
                MR,POWERS
                "Well now you know. Cops break laws all the time, luckily for them they aren't held accountable for most of their infractions."
                New Generation Auto, CJ performance Package STAGE 2
                • GoldenPlump
                  • 6863
                  Toyota has had a shit ton of problems with their FJ frames/bodies.
                    Every forum needs a mobile version like TCS has.
                    • YouNeverSawMeHere
                      TCS' Commodities Specialist
                      • 9057
                      OVERBUILT!!
                      In regards to process welding..... the machine may have been set at too high of voltage... too hot. It sometimes makes the pieces you are welding together brittle around the weld(slag develops a glass like appearance)... the weld is strong but then you have over heated the material's joints around the heat zone which will directly effect any tempering that the material may have had to begin with.
                      And after looking at the photos... I am 100% sure that was the case... now they probably go back and have to inspect the other frames that came out that day to see if it will be a pattern. Assembly lines are awesome but its shit like this that makes you wonder if its worth building them so fast that you lose quality. I am sure that if this story gets any bigger than toyota will make him sign a gag order, they are liable and at least the guy is happy and got what he wanted.
                      Available on Amazon
                      >>Click here<<
                      • Max Power
                        • 13086
                        Those FJs are weird to drive. Because if the vertical front window and the length of the roof overhang in front of the driver, you cant see the stoplight across the street while waiting at an intersection. Really annoying and not terribly well researched.
                        • ACRucrazy
                          • 27924
                          http://www.fjcruiserforums.com/forum...body-rips.html
                          326 pages.
                          • Paul Revere
                            Classier than most ...
                            • 12706
                            WTF!
                            • Bmikkalson
                              • 3333
                              Ok, good to know. I can see how you tied the motor mount problem with the the front window.
                              MR,POWERS
