Thanks again to Timmah for the new stainless oil feed...worked like a charm, no more leaks (so far).
Also, the 2.95 pulley works better than I had anticipated....12lbs of boost by 6000rpm (which is about 3psi more than I was making at that rpm with the old pulley). Should hit 14 or so by 6600 if it holds. No perceptible belt slip so far. I was expecting it would hold until around 5000rpm and then it would slip like crazy (it was only a test).
Feels good to have accomplished some work on the car myself.
Carry on.
Carry on.
Good to hear it is holding. a griperater will easily hold it if needed.
