Electricians please help me.
  • 351capri
    64 fairlane someday
    • 14584
    My washing machine temp control does not change, no matter what setting i have it on, its always just warm, not hot, not cold, so i took a volt meter and checked continuity with the six prongs on the temp control switch. on every setting, i get a reading, but, the reading is not always 0 on the meter, so could the switch be bad? Thanks.
  • xjfish
    siiiiiiick!
    • 7357
    Sounds like a bad switch to me. Does the resistance change steadily as switch is turned?
    1987 Oldsmobile Cutlass Ciera
    • 351capri
      64 fairlane someday
      • 14584
      yep, i have to move the test leads as i rotate the switch, on a couple settings it reads 000 and on another setting it read like 060 or something like that, and on one other setting it read about 320.
      • SmithEvo
        Poppin' VTAK yo!
        • Nov 2004
        • 25468
        Just buy another washing machine... problem solved.
        Not at the table, Carlos.
          Without knowing what the switch is supposed to ohm out at, I'd check elsewhere first. Is the hot side hose kinked or collapsed?
          • 351capri
            64 fairlane someday
            • 14584
            No, no matter what setting its on, you can feel both hoses and both hot and cold water are entering. Im thinking its not the inlet valve , cause when you pull the knob out, it opens up both hot and cold sides. Its also has ATC (auto temp control) on the knob too, so there is a circuit board under the control panel. So im not even sure where to start.
            • 351capri
              64 fairlane someday
              • 14584
              Thats what my friends tell me, but, i tell them to give me 500 bucks or whatever they cost, and i will do that , i would rather buy a 20 dollar part if i can get away with it.
                I'd look on craigslist for people that repair appliances.
                • SmithEvo
                  Poppin' VTAK yo!
                  • Nov 2004
                  • 25468
                  GO BE POOR SOMEWHERE ELSE FGT
                    Google
                    • 351capri
                      64 fairlane someday
                      • 14584
                      Google
                      I have tried that, havent come up with anything yet.
                      • xjfish
                        siiiiiiick!
                        • 7357
                        If you can get a switch for $20 I would try swapping it out. I would guess they would want more like $40+ from what I've heard.
                        • Jeffescortlx
                          Frum roll
                          • 2003
                          My washmachine control is'nt varible (not a potentiometer) just a hot, warm and cold. So the switch is either energizing one or both of the solenoids.
                          I'm sure you could find a washer on craigs list for next to nothen since people are loosing their houses left and right.
                          • xjfish
                            siiiiiiick!
                            • 7357
                            This is true, I've seen a bunch on CL for cheap. If its an old dog, another used machine would probably be cheaper than the factory part to fix the old one.
                            • SDK
                              #1McMoppoFan
                              • 12342
                              I would replace the control valves and solenoid assembly. Or maybe just take the out and lubricate with some WD 40. Then run it first so you don't get wd 40 on your panties.
