360 help
  • jjhirsch
    hirsch
    • 3776
    360 help
    my brother just got a 360 so we did HDMI to DVI to my 22 inch screen.
    how can i get sound out of the x box is there a way to get it through the controller?
    also we are playing and bad company looks bad for some reason is there a way to turn it up on the 360?
    ty jj
  • SmithEvo
    Poppin' VTAK yo!
    • Nov 2004
    • 25468
    Get sound through the controller??? No.
    Not at the table, Carlos.
    • OffShore
      yes it floats
      • 9995
      dvi is not sound supported. you need to run sound another way other than through the hdmi
      • jjhirsch
        hirsch
        • 3776
        yeah that is what i was thinking but they blows because how can i get sound using my monitor
        • SmithEvo
          Poppin' VTAK yo!
          • Nov 2004
          • 25468
            ty jj
            Piece of cake.
            Just go and take off that big huge gray plastic cover on the component connection. Also I know you have to fuck around with a few settings in the menu, and then you can plug them into some speakers via RCA or RCA-MiniJack connections. I can't remember what exactly you change
            I think that the trick to get it to work is to switch the Component cable swith to HDTV, so it pushes the video through the HDMI connection, while still carrying the audio out that component connection. 1080 on the cheap
            EDIT: Can't find link right now, but that should start you off in the right direction
            • ACRucrazy
              • 27924
              I dont know about the 360, but on the PS3 you can do video out of the HDMI and audio out the fiber optic or RCAs, its just a setting in the menu.
              If you can do the same in the 360, could run RCA-mini jack to your monitor?
              EDIT: after typing this I see fernanernie just said the same shit.
                You're gonna get raped
                Every fucking time I see that guy I snicker
                  Originally posted by SmithEvo View Post
                  You are a prick. What is the price? I promise to keep it well. It will not be abused.
                  • jjhirsch
                    hirsch
                    • 3776
                    gray plastic cover but it seems like i will brake it if it take it apart on the tv plug in cord
                      PUMP UP THE VOLUME!
                        If you do it carefully, you won't
                        • Blizzard
                          John Brown
                          • 1177
                          this is what I use, connected to a VGA switch box to switch between xbox and PC. Picked it up for $9.99 used.
                          Unfortunately, the page you are looking for could not be found or no longer exists. Please use the helpful links on the page, the site navigation, or the search bar to continue browsing the GameStop website.
                          TCStangs.com for even those who haven't owned a Mustang for years, you stay for the drama
                          Originally posted by specialk922
                          I'm a girl, I use lotion because it's a girl thing to do, not because I need it to rub my penis.
                            Tremendous.
                              http://www.gamestop.com/Catalog/Prod...oduct_id=40681
                              Good luck getting HDCP content through that
