Help with Dell Desktop Gx260
  • Black87GT
    Keyboard Warrior
    • 996
    Ok, well my father bought a new computer from his work and brought it home and im trying to get it setup, but the problem is when i turn it on it goes to a "Log On to Windows" screen with a username and password, (windows xp professional) well i dont know the password for it, and it didnt come with any cds to reformat the harddrive or anything like that.. so what should i do to get on this computer?
    i have no idea what else to do, there has gotta be a way to reformat it, and i need on it..
    '87 Gt- (Black) Underdrive Pulleys, bbk long tubes, Weld Draglites (Big and Littles), 3:73 Gears, bbk o/r H-pipe, 2.5" Flowmaster 40s, Cobra Upper/Lower intake, pro 5.0 short throw, zoom stage 3 clutch and flywheel, No smog equip., Soon to have an Aluminum D/s
    '97 Explorer Sport - (Green) All Stock 4.0, Runs great (DD)
    http://www.cardomain.com/ride/2574854
    If he bought it from his work then tell him to ask for the password.
    • Black87GT
      Keyboard Warrior
      • 996
      He already did, they said its been there for awhile since they are shutting down and have no idea of what the pass is...
      • 00Formula
        • 3923
        You might be able to press F1 when it first starts to boot up and in the master set up screens there may be an option to reformat windows XP; however, this will highly depend on how good/ tight IT at your dad's company was and if they blocked that feature.
        Originally posted by retics4me
        Im not very smart but I can lift heavy things
          I bet one could Google "XP Password Reset" and get a bunch of results
            pffft...
            try using Administrator? Without a password. It MIGHT work. Otherwise have him bring it back in, and have the IT guys wipe the PW.
            • sc0tty8
              Raised by wolves
              • 4134
              No sig for you.
                pffft...
                They don't know the password.
                Also make sure you're just logging onto the machine itself, not a domain.
                  Download XP off the internets, and reinstall XP.
                  • HELLFYR
                    Shelby-ing
                    • 3081
                    All optiplex machines come with a system restore CD (for the OS) and a System Drivers CD from Dell.
                    Pops should be able to get one from work.
                    Make sure it is for the GX260, as older model restore CDs may not work with the newer machine.
                    If not, you will need
                    1) Download all the drivers for the machine from the Dell site
                    - MOST Optiplex machines NIC cards will NOT work with a generic NIC driver
                    - You will be gawking along in 640x480 video mode until the video drivers are loaded
                    - The chipset drivers can make a world of difference in performance
                    2) Acquire either XP or Vista... then...
                    Put your OS CD in the CD-drive
                    Setup the BIOS to boot from the CD-drive
                    Reboot the system
                    Go through the setup...
                    New setup, not a repair
                    Delete all existing partitions
                    Create a new partition
                    FULL FORMAT (not the quick option)
                    Let the install complete.
                    Sounds complicated, but is really very simple
                    • Nasssty
                      • 424
                      Just crack the SAM file and be done with it.
                        See post #5 and #7
                        • SicLinc98
                          Sic One
                          • Sep 2005
                          • 3027
                          Or throw in a XP disc, who doesnt have one laying around and reinstall it.
                            asdf
                              The password is locked down inside of the computer. Just remove the side of the case and look for a cube looking metal thing, should have a fan attached to it at the top. Just rip that whole sucker out. Should solve all of your problems.
