Weiand 7280 Intake Manifold... Need help finding Specs
    Cant find anything on Holley's site, or on jegs or summit.
    Google searchs are coming up fairly empty.
    Im just looking for what kind of performance it is capable of, and how big of a carb should be used with it.
  • Max Power
    • 13086
    Judging from the engine it is designed for, I would guess it's a torque manifold, and from the displacement, prolly a 600cfm would serve just fine. That's just a guess. Older smaller Buicks were never rev monsters.
      Uhm.... not a chev intake manifold.
      • Max Power
        • 13086
        Who said anything about Chev?
          • Max Power
            • 13086
            Didn't realize a Buick was a Chev?
            I googled the app and it said "53-56 264 and 322 cu. in" Buick.
            Whatever. Best of luck with your search.
              Yahm thats why i said google searches were coming up with nothing.
              Although i could be mixing up the 7280 Mustangs at home, im at work and just trying to come up with reasons why my car doesn't PULL like 220 RWHP.
                Perhaps because the area under the curve sucks ass?
                  I may just have to cam it this winter.
                  • mg72
                    All Hondas All the Time
                    • 1955
                    Area under the curve is fantastic. 2.7x or 3.0 rear gear is why it doesn't hop. Get yourself a dual pattern comp cams grind if you do(exhaust biased). The exhaust side still doesn't flow that well on those heads. Get the exhaust side ported and an e or x cam would be good.
                    The Jimmy hat is off.
                    • Max Power
                      • 13086
                      Judging from the Google results, 7280 isn't the number you are looking for.
                      Try again.
                      • Video_Master
                        Kickin it Hybrid Style
                        • 10524
                        600 should be plenty of carb for a 302. Hell you can run a 5.8 with a 600.
                          its about this big by this big :makeshandgestures:
                            Well im picking up the 8.8 with 3.73's this Friday...
                            • Xtort
                              • 6968
                              Weiand Stealth 8020?
                              http://youtu.be/GTQnarzmTOc
