How to Give Cat a Pill
  • Max Power
    • 13086
    INSTRUCTIONS FOR GIVING YOUR CAT A PILL
    1. Pick cat up and cradle it in the crook of your left arm as if holding a baby. Position right forefinger and thumb on either side of cat's mouth and gently apply pressure to cheeks while holding pill in right hand. As cat opens mouth, pop pill into mouth. Allow cat to close mouth and swallow.
    2. Retrieve pill from floor and cat from behind sofa. Cradle cat in left arm and repeat process.
    3. Retrieve cat from bedroom, and throw soggy pill away. Take new pill from foil wrap, cradle cat in left arm holding rear paws tightly with lef hand. Force jaws open and push pill to back of mouth with right forefinger. Hold mouth shut for a count of 10.
    4. Retrieve pill from goldfish bowl and cat from top of wardrobe. Call spouse from garden.
    5. Kneel on floor with cat wedged firmly between knees, holding front and rear paws. Ignore low growls emitted by cat. Get spouse to hold cat's head firmly with one hand while forcing wooden ruler into mouth. Drop pill down ruler and rub cat's throat vigorously.
    6. Retrieve cat from curtain rail, get another pill from foil wrap. Make note to buy new ruler and repair curtains. Carefully sweep shattered figurines from hearth and set to one side for gluing later.
    7. Wrap cat in large towel and get spouse to lie on cat with its head just visible from below spouse's armpit. Put pill in end of drinking straw, force cat's mouth open with pencil and blow down drinking straw.
    8. Check label to make sure pill not harmful to humans, drink glass of water to take taste away. Apply band-aid to spouse's forearm and remove blood from carpet with cold water and soap.
    9. Retrieve cat from neighbor's shed. Get another pill. Place cat in cupboard and close door onto neck to leave head showing. Force mouth open with dessert spoon. Flick pill down throat with elastic band.
    10. Fetch screwdriver from garage and put door back on hinges. Apply cold compress to cheek and check records for date of last tetanus shot. Throw T-shirt away and fetch new one from bedroom.
    11. Call fire dept. to retrieve cat from tree across the road. Apologize to neighbor who crashed into fence while swerving to avoid cat. Take last pill from foil wrap.
    12. Tie cat's front paws to rear paws with garden twine and bind tightly to leg of dining table. Find heavy duty pruning gloves from shed. Force cat's mouth open with small spanner. Push pill into mouth followed by large piece of fillet steak. Hold head vertically and pour 1/2 pint of water down throat to wash pill down.
    13. Get spouse to drive you to emergency room; sit quietly while doctor stitches fingers and forearm and removes pill remnants from right eye. Stop by furniture shop on way home to order new table.
    14. Arrange for vet to make a housecall...............
    15. Get a dog.
    Instructions for giving dog a pill.
    1. Remove pill from foil, wrap in steak, give it to the dog.
    • Hotstang
      Ya Trick Ya
      • 4196
      sounds about right...
        buwahahahaha
        • CCr
          The penis has spoken.
          • 10966
          forwarding to people right Meow........
          Originally posted by xjfish
            1. Let cat die.
            2. Get a dog.
            fix.T
            • dwinthrup
              • 895
              your supose to rub it down it's throught
              • slo5ohh
                EX-Motorcycle Stuntman
                • 5606
                Take a stroll out of your house sometime to say the local mall. You will see plenty of teenage corn fed mancows devouring cinnabons like it's their last meal.
                • 02SilverZ
                  Z is for Zora!
                  • 3061
                  fix.T
                    Why would you give a cat a pill?
                      When the wine and the mood lighting isnt working....
                      • 02SilverZ
                        Z is for Zora!
                        • 3061
                        Wrong on so many levels.....
                          Here I thought you could just get them spayed.
                            My cat is on Prozac.
                            Seriously.
                            • Tommy
                              Invisible
                              • 646
                              Wrap it in soft cat food. Try tuna too. Or open the mouth and shove it in.
