Pin Stripe removal....
  • sc0tty8
    Raised by wolves
    • 4134
    So, darkdan tells me there is a tool that can do this, does anyone know where I can get one other then the internet? I like instant gratification
    If this don't go here, move it to the detailing section!!!
    No sig for you.
  • Spiral
    Crayon Guy
    • 8157
    3M Stripe Off Wheel Adhesive Remover Eraser Wheel Removes Decals, Stripes, Vinyl, Tapes and Graphics 4” diameter x 5/8” thick 3/8-16 threaded mandrel 07498 Pack of 1: Power Rotary Tool Accessories: Amazon.com: Industrial & Scientific
    I have one in my garage although I prefer just using a razor blade and get it under the vinyl and run down the car with it rather than using that thing.
    2013 Raptor
      just heat up the stripe and peel it off
      • Tommy
        Invisible
        • 646
        Whatever you don't use a metal razor blade!!! Just heat it up with a hair dryer and peel it off. If it is one of those "painted" stripes, heavy solvent or alcohol will eventually rub it off. But do the hair dryer thing first.
        • sc0tty8
          Raised by wolves
          • 4134
          Originally posted by Spiral View Post
          http://www.amazon.com/3M-Stripe-Whee.../dp/B00063VT0G
          Is that 3m thing hard to use?
          You think it'll come off that easy.
          No sig for you.
            Heat gun and hope like hell there is no paint line from previous paint work that ends at the stripe.
            • darkdan
              got tint?
              • 2203
              I gave Scotty some plastic razor blades to aid in his paint destruction.
              IMO, Heat Gun + Plastic Razor Blade + 3M General Purpose Adhesive Remover.
              If you wanted instant gratification you would have started peeling them off by now!!! Obviously, you can wait a few more days. =)
              I'm Dark, I'm Dan...I'm Darkdan
              www.HurricaneTint.com
              Tinting and 3M Paint Protection Film (Clear Bras)
              Mustangs tint jobs starting at $170 for board members
              Vinyl Signs and Decals
              AMSOIL Dealer http://www.dantheoilman.com
              Online Vitamin/Enzyme Store
              • sc0tty8
                Raised by wolves
                • 4134
                I started here and there to see what I was up against, didn't do anything drastic, yet.....
                Maybe this weekend I'll get out there with my bucket and sit on my ass and work my way around the car
                No sig for you.
                • Spiral
                  Crayon Guy
                  • 8157
                  Ive used metal razor blades before and the trick was to keep it between the vinyl and the adhesive
                  2013 Raptor
                  • Spiral
                    Crayon Guy
                    • 8157
                    another tip is to do this in a garage where the solvents from the 3m adhesive remover wont evaporate as quickly, and spray the adhesive remover on before using the blade, this helps tremendously allowing a smooth run along the pinstripe, without the solvent to break away the adhesive the blade will hang and potentionally cause you to dip into the paint.
                    2013 Raptor
                      Like your hand is that steady.
                      • darkdan
                        got tint?
                        • 2203
                        I've been known to lay plastic over it and let it really soak in and soften it up.
                        • Spiral
                          Crayon Guy
                          • 8157
                          If I smoke a bowel it is
                          2013 Raptor
                          • Crotchrocketcbr
                            • Feb 2005
                            • 2826
                            we got em at my work
                            carquest automotive finishes (GT parts)
                            1166 robert street in west saint paul
                            Originally posted by Paul
                            I'll bet you a pop payable at Porky's that TJack starts the season!
                            • SmithEvo
                              Poppin' VTAK yo!
                              • Nov 2004
                              • 25468
                              he practices by cutting the cocaine
                              Not at the table, Carlos.
