Computer CD Drive problem
  • SmithEvo
    Poppin' VTAK yo!
    • Nov 2004
    • 25468
    My CD drive will not recognize any DVD's or CD's. I put them in, the drive spins them up, but the E: drive remains empty. I've tried rebooting my driver, updating my driver, etc. Any other ideas?
    Not at the table, Carlos.
    Plug in the IDE cable.
    It's possible you might need a new drive. They're pretty cheap anyways.
    • SmithEvo
      Poppin' VTAK yo!
      • Nov 2004
      • 25468
      its a sony vaio laptop. I would assume the drives for laptops are a bit more expensive I dont know what an IDE cable is, but since the computer will eject the cd drive, I would guess it's plugged in.
      • S40Monster
        ElectraFied
        • 3080
        A cd drive will eject without the ide cable plugged in, all it needs in order to do that is power. The IDE cable is worth checking considering it's free, but I suspect you'll be buying a new drive.
        • Chrm97PI
          268ponies with more onthe way
          • 3413
          time for a new drive
            sounds like you're in need for a drive, maybe the eye took a poo poo. known sony problem since the days of windows 3.1
            • Video_Master
              Kickin it Hybrid Style
              • 10524
              there is no IDE cable cause it is a laptop. Does sound like the drive went south though. I would check out e-bay for a new drive and this time you could purchase a DVD writer for it.
              • CorinthiansBlackGT
                • 4235
                sometimes my laptop CD wont recognise DVDs...
                Usually if i open or close it a couple times or push the drive in a little tighter to seat it better against the prongs in the back of the drive where it connects to the main board it will start working.
                Then again, my laptop is held together with duct tape, wood screws and super glue... I also turn it on with a paper clip :\
                Babies stay crunchy in milk!
                • Xtort
                  • 6968
                  Not sure what the sony vio's drive looks like, if it's like ibm/lenovo's you should be able to either flip a switch or press a button and eject the entire drive easily. If you can do that reseat it and try again unlikelybut might as well try. If it is that easy to remove the drive it will probably be cheaper to replace it as well.
                  http://youtu.be/GTQnarzmTOc
                  • SmithEvo
                    Poppin' VTAK yo!
                    • Nov 2004
                    • 25468
                    It is a DVD writer Oh well, time to start searching ebay i guess.
                      Well he didn't specify it was a laptop on his first post!
                      E-bay isn't a bad idea. Just be sure you don't get another bad drive off of there!
                      • sc0tty8
                        Raised by wolves
                        • 4134
                        Its shot. I have had that happen in the past. Hit up ebay for a new drive.
                        I have a cd/dvd burner here, thats just a command and conquer 3 drive now, it no longer opens!
                        No sig for you.
                          Paper Clip
                          • sc0tty8
                            Raised by wolves
                            • 4134
                            Paper Clip
                            That thing that lifts the cd/dvd up is stuck to the disk, when ea or whoever made my c&c3 dvd, they got some adhesive on it, and I did notice it before I stuck it in, but, was in a hurry, and, never did clean that shit off, so, I got pwned
                            No sig for you.
                            • ejholmgren
                              • Oct 2004
                              • 1852
                              stop sticking your hoo hoo in it all the time
                              smoke gray cat mafia (Barn cat)
                              R.I.P. 1/4 mile cat. You died doing what you loved best ... running in front of cars going 120mph.
