220 in the garage?
  • ACRucrazy
    • 27924
    220 in the garage?
    So I have a seperate panel and meter on my garage.
    Its a decent size panel and i believe its rated 200 amps and has only two 30 amp and three 20 amp breakers in it currently.
    Im wanting to get a two stage compressor. Whats all involved in getting that wired properly? Home electrical is where my knowledge is lacking.
    The amp/voltage sticker on the door is not filled in, but the meter on the outside says 240v? It has the 3 wire service head.
    Whats the proper wire gauge (10+?), how hard of a job is it to wire from the service panel to an outlet and anyone wanna side job?
    I dunno, who knows what
    Thanks
  • pubestripe
    Minnesomalia smells
    • 2384
    it is fairly easy to do. i just got a 50 amp breaker, and wired it in... i am running a 2 stage compressor, an old Quincy, and it runs just fine. where in relation to your fuse panel did you want the compressor to stand? that in itself is the hardest part, finding where you want to stand it, because then you have to find out how you want to wire it in... through conduit or the wall...
    I love the hate, gives me a new purpose.
    • ACRucrazy
      • 27924
      yea, right now im in the process of gutting the garage to do it "my way"
      Im thinking temporary I could place the compressor 5 feet or so from the service panel, but eventually, it may end up being about a 60 ft run to the other corner under the heater.
      Two 50 amp circuits could never hurt
      • pubestripe
        Minnesomalia smells
        • 2384
        very true...lol they couldnt hurt. i ran my compressor 6 feet from my panel because i was lazy and didnt feel like wiring it to the other side which is 25 feet or so away, and i already have a finished garage. i think i have 12 gauge in there too, i have to go look because i had to ask my buddy what size to get seeing as how he is an electrical engineer!
        • Gipper
          George W. Randolph
          • 5228
          If I'm reading this right, you're feeding your compressor with 12 gauge wire on a 50 amp breaker? 12 gauge wire is only good for 20 amps which means you will cook your wire and possible start a fire long before the breaker will pop if something happens. During normal operation it should be fine but if for some reason the motor starts to draw more amperage or if there is a short the wire will over heat before the breaker will trip.
          Amp ratings for copper wire
          14g = 15amps
          12g = 20 amps
          10g = 30 amps
          8g = 40 amps
          6g = 65 amps
          • Gipper
            George W. Randolph
            • 5228
            Thanks
            Look at the amp/volt spec on the electric motor on the compressor. If it’s 240 volts then you will need a “2 pole” breaker. Then look at the amps on the motor…. It will probably be between 20 to 30 amps. Whatever it says, that is the size breaker you need. Example: If it says 240 volts and 30 amps…. You’ll need a 240 volt, 2 pole, 30 amp breaker fed with 10 gauge wire. Now, here is the part where you’ll need to know the brand a model of the panel that is currently in your garage so you can get the correct breaker. Examples: “Square D QO”, Square D Home Line”, “Cutler Hammer”, “Siemens” ect….
            Wiring…. There is no neutral (in most cases) when wiring 240 volts (neutral is usually the white wire) but you will need a ground. If you are using EMT conduit then the EMT acts as the ground itself…. If you are using romex then you will need to attach the ground conductor to the ground buss in the panel and to the compressor pressure switch.
            If you want to “Hard Wire” the compressor you should have a disconnect (a double pole switch) within reach if its not near the panel. Or you could wire an outlet and put a cord with a plug on the end to plug in the compressor.
            Don’t worry… you’ll be able to tackle this yourself. It sounds intimidating but it isn’t to bad.
            Hope this helps
              Wait...I thought the previous owner was welding in the garage. What happened to the 220 runs? Or was he using 110v welders?
              • NAZISALEEN
                Afro Samurai
                • 12235
                I can help you do it. I have gained alot of home wiring expeirence in the last year.
                Now how soon do you need it done
                Shouldn't be a big deal, sounds like there is 220 there now.
                • Video_Master
                  Kickin it Hybrid Style
                  • 10524
                  TRDon is an electrician.
                    No he isn't, you lie.
                      PM TRDon. Two things a person shouldn't do themselves unless they're trained. Electrical and gas plumbing. You fuck shit up that way.
                      • 10k lakes
                        • 1045
                        if you are looking temporary, use range or dryer cable and 3 or 4-wire receptacle and plug. by far the cheapest way if you are only looking temp for now. Aluminum wireis the way to go if you are looking for a short term.
                        you'll need
                        -a breaker (see name plate on the compressor motor) [$10-20]
                        -the wire just get Type SER Aluminum cable (dryer cable is for 30A and range is 50A) [15ft #6SER AL (50A) $22.50 15ft #8SER AL (30A) $14.40]
                        -one or two romex connectors should be a 3/4" or 1" depending on which size wire you need [$1.00 EA]
                        -an angle plug (30A or 50A P&S #3867 or equal) [$16.80 EA.]
                        - surface receptacle (P&S #3854 (30A) or #3884 (50A)) [$9.00(30A) $9.25(50A)
                        Like said above you might not need the 4-wire and might only need 3 wire but I guess I always go on the 'just in case' side of things, its easier to have an extra wire to start that you might not use than to need one later after you have a wall covered or a conduit full. Plus at the last garage I wired he liked the 50-60A wire everywhere in case he needed a welder outlet etc etc. that way he could.
                        '07 FUSION SEL
                        '07 EDGE SEL
                        • Nifty
                          Hippies aren't really people..
                          • 5685
                          Shit. I may have to do a little upgrading too. How hard would it be to just add a couple 4 plex outlets to my garage?
                          "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves."
                          - Ronald Reagan
                            Piece of cake. Is your breaker box in the garage?
                              I havent gotten a PM
                              PM me your phone number and I will give you information that is true and legitamate and to code and if you feel comfortable doing it, feel free, if not, we can figure something out.
