Who sells Gatorback belts?
  • sturte30
    400hp and AWD....Droooool
    • 3392
    Locally.....My gates belt that I have sucks my ass. Noisy as hell when I get on it sounds shitty cause its slipping/making slipping noises. Anywho I have read that gatorbacks are nice and quiet. SO where can I get one?
    "There is a fine line between a hobby and a mental illness"
  • Fastrnu
    • 265
    Are you running a polycog or green stripe gates?
    • FASTANG
      not really, but someday
      • 1294
      I got mine from Autozone earlier this winter.
      Taryn
      Want to see more? -->'95 GT
      • sturte30
        • 3392
        Green stripe and it squeals like a girl when I get on it. FYI I am running all 4 billetflow idlers and a 2.76" pulley.
        • Fastrnu
          • 265
          Really. I was running the Gaterback and I hated it. Shreaded them constantly. I switched to the Green Stripe and haven't had any problems since. I'm running the same setup you are with a 4lb lower.
          Have you been driving it in these cold temps? Maybe that's it????
          • Video_Master
            Kickin it Hybrid Style
            • 10524
            The gatorback belts leave lots of black dust. Get a green stripe gates belt that is the proper size and you will not have issues.
            • Video_Master
              • 10524
              What size belt are you running?
              • sturte30
                • 3392
                Yeah I have been driving it in cold temps. I have noticed black dust on the blower snout so idunno. I am going to give the gatorback a shot.
                  Autotone
                  • sturte30
                    • 3392
                    Not sure. It was what was on there when I bought it. I guess I just assumed that the proper belt would be on it. Also it didn't do it the whole drive up from texas. Just started about 2 weeks ago.
                    • AnotherV6
                      Custom User Title
                      • 304
                      Like this one?
                      J/k Autozone for $29.
                      04 A4 1.8T 6Spd Ocean Blue
                      • Video_Master
                        • 10524
                        I went with a slightly smaller belt and I have the 4 idlers and the 2.76 and I use the following and have had no issues and using the same belt for 1.5 years.
                        I have K080745 Gates Green Stripe
                        That is a 74.5" belt which is .6" shorter then the stock belt. I have had no sign of belt slippage or anything with that.
                        • sturte30
                          • 3392
                          Where did you pick up your green stripe from? The 74.5" fit with no issues huh? Dumb question but wouldn't a shorter belt put too much tension/stress on the s/c snout?
                          • Video_Master
                            • 10524
                            Where did you pick up your green stripe from. The 74.5" fit with no issues huh? hmmmm
                            It fits but it is very tough to get on and what I did is remove the AUX idler from the bracket and then put the belt on and then put the AUX idler back on once the belt was on. Made it much easier. I ordered my belt online from RockAuto.
                              Gatorbacks have a lifetime warranty, mine squeeks damn near every year and they just give me a new one.
