And my next years engine size will be..........................
  • drag79stang
    grumpy old fuck
    • 592
    4.100 stroke............4.125 bore............compression ratio yet to be determined....................================ 438 cubes...........
    You can sleep in your race car, but you can't race your house!
  • Mullet Tuner
    • 15906
    What fuel are you going to run it on?
    Originally posted by Gerald
    • Sleeper
      Reasonable volume.
      • Nov 2003
      • 14888
      french fry oil is my guess.
        • Mullet Tuner
          • 15906
            Originally posted by black z View Post
            would youquit with that damned thing! its worse than the smiley!
              can i have your old engine?
                  • SmithEvo
                    Poppin' VTAK yo!
                    • Nov 2004
                    • 25468
                    Not at the table, Carlos.
                    • slo5ohh
                      EX-Motorcycle Stuntman
                      • 5606
                      Take a stroll out of your house sometime to say the local mall. You will see plenty of teenage corn fed mancows devouring cinnabons like it's their last meal.
                      • Mullet Tuner
                        • 15906
                          • ACRucrazy
                            • 27924
                            :rotate:
                            • drag79stang
                              grumpy old fuck
                              • 592
                              Have my old engine?...................Only thing that won't be re-used are pistons, (obviously), and dampner. (got a new ATI super dampner instead of the generic summit one I had previously).
                              Also going to run a crank trigger setup this year.
                              As far as fuel, still the same old 114 stuff.
                              Again, still don't know what the final compression ratio will be , (hopefully at least what I was running, (14-1), but more would be ok.
                              It'll be a while before it's together and dyno'd, although this year we're gonna dyno it with the 'juice' as well. (just so we know).....:>)
