smells in my house
  • I was fast
    addicted to the spray
    • 3679
    smells in my house
    so i wake up at like 5am my 3 year is throwing up and has been once an hour and its smells funny in hear like burning plastic or electric burning smell its coming from the heater ducts i think. check around EVERYWHERE nothing hot anywhere and no fires or anything. anybody know what this smell could be? we are thinking maybe dust and crap in the ducts??
    "queen bee of the power tour mafia"
    team Y.P.R. :3gears:
    Originally posted by orange88
    i have your tool in my hand
  • One Wheel Squeal
    the one in charge
    • Aug 2006
    • 193
    why would there be crap in the ducts?
    • I was fast
      • 3679
      i dont know, dust maybe who knows the last time there have been cleaned out
      • I was fast
        • 3679
        okay so i shut the heat off and the smell is going away some stink still lingering but not as bad, but i cant have the heat off all day
          Not good.
          • I was fast
            • 3679
            whats not good, should i like leave the house or what. i dont wanna blow up or anything
            • Grenade
              • Mar 2005
              • 3659
              Call a heating and a/c company, and ask them, see if somebody can come out.
                Dust in the ducts would be burned off when the furnace first fires up in the fall. Something could have gotten into the furnace, sometimes birds sit on the exhaust stack and fall in, but usually they end up flying around in the ducts.
                If you're handy you could take a peak in the access panel while the furnace is off. Otherwise have someone come and look at it.
                • KrisR
                  KNT-SHO
                  • 12737
                  ^ I agree. If your kid is sick from it, it can't be good. Call and get someone out there to make sure your house (and air in it) is safe.
                  Good luck.
                  • mark5
                    4fastfun
                    • 1219
                    I had what sounds like the same thing happen and it turned out to be the blower motor in the furnace going bad, I smelled it and then i even ended up seing a very light smoke in a couple rooms. stunk like wires burning. I don't know if thats your issue but it sounds like a possabilty. Good luck hope the little one is feeling better.
                    • I was fast
                      • 3679
                      i guess the hvac guy at work told mike to come home and check out a bunch of stuff. im not sure if my son is sick from that for just sick. i didnt smell anything until around 5am, he was throwing up since abotu 2am. it seems like the heat is going off and on tooo fast. like it will turn off, then a min. later turn back on. and keep doing that. i shut the heat off and the smell went away, i turned it back on and it took around 10 min. to turn on but it doesnt smell that bad anymore
                        Since its cycling so fast its probably the blower motor. The motor goes into thermal overload and shuts off to quickly causing the cycling. Have someone take a look at it.,
                        • I was fast
                          • 3679
                          well no carbon monoxide in here and the motor is fine. still unsure what caused this this morning. everything smells fine now!!
                            Sometimes a furnace will just smell when it has to strt up and run hard for the first time in the year, alot of shit can get down in there..
                            Was funny because just reading the title of the thread I almost posted to tell you have Mike shower more!
                            • I was fast
                              • 3679
                              lol, its not like its the 1st time the furnace has been on though is whats strange, buts its running too much i think. it shuts off for like a min or two then turns back on
