Electric heaters
  • Spiral
    Crayon Guy
    • 8157
    Had it, not worth it... Way expensive to run.
    2013 Raptor
    • GarrettGTX
      • 3648
      There is no Gas run to this house, so it HAS to be electric.
      cunnilingus with a side of coitus
      • Spiral
        Crayon Guy
        • 8157
        Oh... Well it then does the job. I ran two of them but I have a larger garage. Did it one year and the next I paidxcel to run a gas service to the garage.
        2013 Raptor
          Why can't you use propane? Millions of people run it.
          • 9GUY9
            • 3104
            I put this in last year. http://www.amazon.com/Mr-Heater-Natu.../dp/B000HEA7LQ
            I got it for $350 plus $25 for a lp conversion kit from lowes. Works great runs of a regular thermostat so I can keep a consistant temp. I had a local gas company bring me a 120 gal propane tank and set it out side the garage. I ran about 12' of black iron pipe and was good to go. It cost $180 to fill the lp tank and I used 1.5 tanks last year keeping a 24'x28' garage at about 55 degrees.
              Yeah I bought a 100 pound tank on craigslist for 30 bucks. Costs me $70 to fill. Went through about $100 worth of propane last year heating my large garage. You'll spend way more on electric bills plus propane will work better.
              • Spiral
                Crayon Guy
                • 8157
                I spend about $100/month in the winter for my gas and electric. One month I ran the electic heaters it was $250 for that month. Propane is definitely a second choice to natural gas. The reznor I bought came with both regulators and orifices for natural gas an rpropane. If you got a LP unit you could upgrade when natural gas came available.
                2013 Raptor
                  My dad had one of those in his 20x24 shop. It works OK if you don't have gas, but he didn't use it to maintain a temp. He only turned it on when he was going to work. You have to turn it on about 2 hours before your want to work and if it's less than 15 degress out it could only get his garage to about 45-50 running constantly. His garage had no ceiling sheet rock though. I imagine using it to maintain 50 degrees would be expensive.
                  • billb
                    • 490
                    Hmmmm, glad I ran across this topic. I have a 24x24 garage with 10' walls. Going to insulate it and sheet rock it, and had thought about buying a 5000 watt electric heater from Fleet farm since it is on sale for $220, but would not be opposed to also having a 100lbs propane tank outside the garage and running it into the garage for a heater, just not sure size/model would be a good choice?
                    ps
                    How much is it per gallon/lbs to fill a propane tank?
                    pss
                    I do not have a gas supply to the house, electric only.
                    71 Nova, 454/th350, 2800 stall, 8.5 4.10 posi, kinda stock , soon to pull 454/th350 and get LSX transplant
                    74 Dart
                    97 F150
                    00 Escort ZX2
                    99 Sable LS
                      The Big Maxx heaters like 9GUY9 posted are on sale at Fleet Farm right now though next saturday.
                      75k BTU for $469. I'll be picking this one up next Friday or Saturday
                      45k BTU for $400 but its not listed on-line, although it was in stock in the Owatonna store yesterday.
                      • 9GUY9
                        • 3104
                        with 10' ceilings i would recommend getting the 75k btu heater. i only have 8' ceilings in a well insulated 680 sq foot garage and my 45k btu heater runs quite a bit on cold days.
                        Also you want a 100 gallon tank not a 100lb, theres a big difference. I believe it was around $2 a gal last time I had mine filled.
                        • billb
                          • 490
                          If you don't mind me asking, who do you use for propane? I assume with a 100 gallon tank that they need to deliver the propane? Not sure a propane truck could get to the back of my yard as my 1/2 ton barely can get through the gate Maybe electric will be my only real choice......
                          74 Dart
                          97 F150
                          00 Escort ZX2
                          99 Sable LS
                            get a torpedo heater. I have a 175k BTU that will melt your face on full blast and on low will heat a 20x 20 in around 15 minutes.
                            • 9GUY9
                              • 3104
                              I use Ferrelgas, I called the 3 or 4 places around Kato that rent tanks and they were either the cheapest on lp, or able to set it up the quickest. This is a 120gal tank. I was told its the largest they could do with out a city permit. The truck that fills it parks where the yukon and camper are and runs a hose to the tank.
                              I like the fact that you can use a regular house hold thermostat with these heaters, I leave the garage at around 55 all the time. The exhaust is pretty easy to put in, you can go out the side or up and out the roof.
