2 351 Short blocks! 1High Output!
    Mustangless
    • 18133
    Both blocks are torn down right now, youll get both.
    First one is a standard 351W, everything is still there, i believe. Just torn down to block, cam and pistions and stuff still in. (pan is off, heads and intake are off, timing set is off.. ect.)
    Second one is a 351 HO,EFI, looks to have been run low oil and over heated, This is complete. Dunno if the block is even good any more, 1 piston might be froze in.
    $350 For the pair. EDIT! Dropping to 150!
    hard stuff is done on the first one
    Edit3: looking for some one to finish my motor swap, and put in my front end springs. if you do this, ill paywith the 2 blocks
    Edit: Added Short to title
    edit2: dropped price
    Edit3:
    Mustangless
    • 18133
    Cmon up to the top... Look at me.. buy me..
    Will take 250... but you pick up, 350 ill deliver
    • TurboX2
      friend of the machines
      • 3245
      Change your title to 'shortblocks' (what you are selling) instead of 'blocks' and you might get more reads.....
      Dan Simons
      '11 5.0, 400a, 3.73s, HIDs, ARH 1-7/8" longtubes, Forgestar CF5v 19x9/10, MPSS 275/295, GT500 axle-back, Steeda springs, AirRaid CAI, BBK 85mm, AED tune
        Mustangless
        • 18133
        150$ takes them. need them out
        • DNeinstadt
          Administrator
          • 12578
          What years are they and do you have the EFI intakes?
          Dan
            Mustangless
            • 18133
            1 efi intake on the one motor.
            i think 1 is 89 and other is 90
            The HO motor is complete -harness intake heads. thats all i can think of thats missing from that motor.
            other 351 is NON HO, Complete, torn down to block with pistons and cam in it. The #8 cyl had a bad oil leak and so that Heads NEEDS to be re done.. Might as well do both heads
              Mustangless
              • 18133
              any one want these?
              • MetallicPony
                • 14093
                hrm...i should throw a 351 into the vert
                • allstock93gt
                  does not visit often!
                  • 1959
                  yeah you may get into the 14s then jimmy!
                  it's almost allstock! except the wheels.
                    Mustangless
                    • 18133
                    Buy them!
                      that has 408 written all over it... c'mon someone help the guy out he's got a kid on the way
                        Mustangless
                        • 18133
                        look at it this way. you get 2! not 1! for 150. Granted its gonna be some work... but youve got 2 motors!
                          if i had $150 laying around i'd jump on it joe
                            Mustangless
                            • 18133
                            good to know. Like to move them out soon, Would be willing to do 125 but honestly coulnt take less.
                              Mustangless
                              • 18133
                              go up top.
