Black 5.0, 5spd, Hatch back. Gray interior is nice, non smoker. 83,xxx original miles. Winter stored. All power options work, including power windows, locks, mirrors, steering, and brakes. Air Conditioning blows cold. Exterior is in good shape. This car has not been wrecked, the paint is original as far as I can tell(all of the vin tags on the fenders, hood, trunk lid, etc still match and show no noticable repaint lines.) The wheels have been converted to a 5-lug set up, the rims are Ford pony's of 94-98 vintage. Here are some mods:
Holley Aluminum Heads
Holley Systemax Upper and Lower Intake
Holley (Lunati)Cam Shaft
Hardened Push Rods
Double Roller Timing Chain
Trick Flow 1.6/1 Stud Mount Roller Rocker Arms
Ford Racing 30lbs/hr Fuel Injectors
BBK 70mm Throttle Body
BBK 70mm EGR Plate/Spacer
Pro-M 73mm Mass Air Meter, Calibrated for 30lb/hr injectors
Holley Adjustable Fuel Pressure Regulator
Walbro 255LPh Fuel Pump
Ford Racing 3.73 Rear Axle Gears
Accel Life-Time Reusable Cotton Air Filter
BBK 1 5/8 inch Headers
2.5inch H-pipe into High Flow Mufflers
Mallory Ignition Wire Set
I think this car is worth considerably more than $6999.00 Price is firm. If you are interested please let me know.
Randall Crumpler
randallcrumpler@hotmail.com
Located in Ramsey, MN
763-427-0486
Hardened Push Rods
Randall Crumpler
763-427-0486
