Hard braking with new setup, left front locks up
    I have been messing with the bias knob, I think I got it close.
    However, my left front locks up quite a bit sooner than my right front. Is there any way to fix this? I have bled the shit out of them, I'm fairly certain there is no air in either.
  • OffShore
    yes it floats
    • 9995
    bleed your brakes, start w the closest to the driver lf rf lr rr in that order.
    • shineynitelite
      TURBO SPINNINNNN
      • 5715
      actually thats backwards, you want to start furthest away from the master cylinder.
      Originally posted by FortiethStang
      Shagwag, were you in the car craft auto x last year? I remember a wagon running the course..
      • 1QUICK4
        \m/Hail Satan\m/
        • 1123
        +1
        RR/LR/RF/LF
          Originally posted by 1QUICK4 View Post
          +1
          RR/LR/RF/LF
          for those who would ask "when facing the car or while in the car?"
          1. Passenger Rear
          2. Driver's rear
          3. Passenger frong
          4. Driver's front
            I'll try it, but I have probably bled out 2 bottles of fluid already lol!
              are the slides greased? Are the attachment bolts all with good threads or good bite? I've seen a moving caliper caused by such a thing and it would grip hard
              • 01darkblueTA
                highest average street king
                • 13415
                are the calipers supposed to have a anti-vibration clip of some sort?
                Jeremy
                • Steve
                  eMechanic
                  • 5381
                  Are you using a 2 or 3 port MC? This issue inherent in the 3 port system.
                    86 is a 2 port system, I now have a 85 towncar master cylinder which is also a 2 port.
                      Are the front disks the same thickness? I was told it didn't matter once so I tried it, the one side would pull all of the time.
                      A sticky caliper won't release when you let go of the pedal. If you're not sure take it apart and see that it isn't binding. I'm also thinking if the pads/caliper aren't even or binding it may be causing the problem.
                      1. Passenger Rear
                      2. Driver's rear
                      3. Passenger frong
                      4. Driver's front
                      Ahaha, you said frong.
