mods for auto-x
  • MetallicPony
    • 14093
    mods for auto-x
    alright, i'd really like to get into auto-x this up coming summer, especially with all the progress tcs is having with the met council and the events that are coming up.
    i'd definitley like to do some mods to the 5.0 in the spring for these events. i was thinking along the lines of subframes, springs, wheels/tires, but i am open to any suggestions you guys have.
    tire wise, would it be possible to use the 16" wheels i have now(and get a different set for daily driving) with a different tires(need suggestions on a good auto x tire for cheap), or should i buy a larger wheel?
    what springs/other minor suspension mods? i just want to make my car turnable as cheap as possible
    any other performance mods i should look at? i'd like to do h/c/i someday, but other than that i dont know what i could do for the time being.
  • GermanGuy
    TCS AutoX Driver
    • 168
    It all depends on how much time you have....there is some relitively inexpensive things you can do, that just take a ratarded amount of time. springs and tires a good start, talk to flash about his tires. they are sweet!
    SandLImports.com
    Owning Flash with 4 less cylinders and a roots Blower
    Member of the:1475 lbs Mafia
    Originally posted by Stormwalker
    I'm just flakey.
      Subframes First, Full length. Then I dunno, depends on how much money you have.
        From what I understand, subframes might bump him up a class.
        First things first Jim. The most important "mod" you can do for autox is tires, tires, tires. Now, are you planning on using this set of tires exclusively for autox? You said in your post something about having two sets of wheels and tires. If you want to make that sort of investment, you could just accept that bump in class, and go with Victos and subframe connectors. Otherwise, if you are just going to use one set of tires for everything (street/autox), then you will have to look for other options.
        We can give you some links to good tires. Something along the lines of this:
        So basically, do tires first. Then start worrying about other things if you want.
        • MetallicPony
          • 14093
          i was thinking about having a set for auto-x, and another for daily driving/cruising all depends on how much i have to spend of course
          if i went with a set of victos, can i run them on my 16" wheel that i have now, or would it be better to move up to a 17/18?
          i'd really like to do subframes regardless, seems like those who have had them put on said it makes a night and day difference in the car, any recommendations on a full length set? i was looking at the maxim motorsport xl series ones, seemed pretty nice and not too bad price wise
          • Steve
            eMechanic
            • 5381
            As a novice You won't notice a difference between a 16 and 17" wheel. 16" tires should cost less, go with 'em.
            • punch
              I'm back, what did I miss?
              • 23979
              shocks/struts/springs mang
                Blah, I use one set of tires and I do ok. I was a few seconds behind Steve and he was on slicks. For the initial cost of entry for wheels and tires, I would do subframes first. Verts are flimsy as shit, and need all of the chassis stiffening as possible. I am not going to buy wheels and tires for a long time. I am going to burn up my yoko’s. Subframes, lower chassis brace, struts, shocks, springs. You could do all of that for 1000.00, the same price for rims and a nice set of tires.
                Who cares about class bumping? I do it because it's fun. I care not which class I am put into. Better to stiffen the car than have the body twist and have the doors not shut properly from abuse.
                  Very true. Subframe connectors are a must in any Mustang, especially verts.
                  • MetallicPony
                    • 14093
                    are there any special requirements for racing because i have a vert?
                    • bad-speller
                      • Feb 2004
                      • 943
                      As a newbie, your best investment is to learn to drive first. When you can drive street tires consistantly at thier limit, then upgrade tires. Spend your money on seat time and in the long run you will be faster than people that jump right to sticky tires.
                      Subframe connectors are always a good investment. Do springs if you want them for other reasons, they arent going to make you faster at this point. Besides, the ideal spring rate now won't be what you need down the road if you continue to mod the car or learn to drive faster.
                      Brian
                      2006 NASA American Iron Midwest Champion
                      2005 NASA American Iron Midwest Champion.
                      2010 Camaro SS (My New Racecar, coming soon)
                      08 Corvette Z06
                      09 BMW M3: Interlagos blue, SMG II
                      00 Mustang Cobra R
                      95 Mustang Cobra R (#23 NASA AI midwest)
                      94 Mustang Cobra (#23 NASA AI midwest) SOLD
                      09 BMW X3
                      My braking point entering a corner is when I see the corner worker raising the yellow flag for me
                      • Steve
                        eMechanic
                        • 5381
                        Brian
                        You getting sick of saying this yet?
                        I think it's time for an autoX for newbies sticky, and some corner-carver-ish enforcement.
                        • GermanGuy
                          TCS AutoX Driver
                          • 168
                          agreed go try it first and make sure you have fun, and its going to be something your going to want to get into. another thing you could do is get a mild alllignment for cone dodging its about 40bucks and the guy that does em is way good. west side tire in corcoran
                          SandLImports.com
                          I'm just flakey.
                            Just start with a descent set of tires....I did suprisingly well with my BFG Traction T/A's (245/50-16 V rated, not H rated like most of them are) and would love to do it on 'em again this year if I didn't already have new wheels to pick up in a few weeks here.
                            • Shadowgray03
                              Snake Charmer
                              • 1141
                              I think an auto-x for newbies sticky is a great idea.
                              Ive breifly looked at the various rule textx and what not and still am not quite sure what class my car would be in. Then again, as stated by other members I guess I dont really care, im not out to win anything, just have a good time and hang with fellow car enthusiasts.
                              I still have stock rubber on my car which is poor from the get go so new tires are definatly in order. I will have to see how the money situation goes because I would like to get different set of wheels/tires altogether anyway.
                              2003 shadow gray cobra
                              VT Stroked, Crower cammed and KB Topped
