I am looking to sell my Notch. I have to many projects and my loss will be someones gain. Here are the specs:
93 4 cyl notch, manual windows-locks, full interior, NO rust.
97 cobra rear axle with 3.27 gears
97 Cobra Front brakes with cross-drilled rotors
Wilword adjustable prop valve / gutted stock valve with proper solid plug
FMS 95 Cobra “R” wheels
2 new yokohama 275-40-17 tires
Maximum Motor sports rear lower control arms
Maximum Motor sports full-length sub-frame connectors
Maximum Motor sports strut tower brace
Maximum Motor sports Solid spherical rear bushings
HPM caster/camber plates.
Koni Double adjustable struts
GMS front coil-overs
Optima red top battery
Moroso trunk mount battery kit
1/0 welding cable used for running lines to and from battery to alt
White face gauges with 200 mph speedometer
Pioneer premier DEX-P1R- Sound-Q CD Player
Infinity compoment system up front
2 10” JBL subs
Sony and Kenwood amps
Cervenis 2 1/2 inch Cobra R style cowl hood
All the wiring in the engine compartment is hidden
New 6 piece headlight set
The Motor:
92 Block 306
TRW pistons
reconditioned factory rods with arp bolts
factory reconditioned crank
HV oil pump and arp pump shaft
F-303 cam
Fully ported trick flow TW heads
Crane roller rockers
Crane pushrods
Trick flow intake
70mm TB
Pro-m mass air and 30lb injectors
Mac headers and o/r H-pipe
u/d pullies
t-5 tranny
Clutch will handle up to 700 HP
New Alternator and waterpump
I am sure there is some more stuff, but a good deal non the less.
The Notch has 79,000 miles on it and all the car would need is a paint job to be completed (white hood and fords "oxide special" red")
Complete: 6500.00
2 10” JBL subs
The Motor:
92 Block 306
TRW pistons
F-303 cam
Crane pushrods
Trick flow intake
70mm TB
u/d pullies
t-5 tranny
Complete: 6500.00
I want one!
