Performance 700R4 build
  • octanehuffer
    • 5265
    Starting a build right now. Anybody want dibs on it? I am just tearing down the core now, so if you want it custom built, speak up. Will need money down if YOU want it built, but it will get the "usual" and be able to sustain 9 sec passes.
    I have a good turbo car recipe for this trans too.
    Adam
  • 94fobrah
    2012 RSN #3
    • 8820
    KABOOOM
    90 LX 445CI N/A SBF
    Built By Dave Senderhauf JR
      I know someone planning a single turbo 350 Camaro. What are you looking for the usual so I can pass it on?
      It has a 700r4, left it in there when we swapped the 350 in.
      • COUGARCAT351
        Don't make fun of Camaros.
        • Feb 2007
        • 660
        except w/ an aluminum 5.3
        If two deaf people are having sex, do they still make a sound?
        • octanehuffer
          • 5265
          The turbo trans will consist of completely different planetaries, shafts and drums. Not cheap.
          However the price of the usual 700R4 is around $900. I need to build it still, so the price is subject to change. It does however, give the opportunity to someone who wants it built their way.
            If you had to guess around 500rwhp with needed turbo resistant parts? I will pass the $900 starting on.
            • octanehuffer
              • 5265
              Well, the average built 700R4 will handle that. There is one out there behind a Big Block Shawn 454 making 550 ft lbs. The 700R4 is good to 600- 650 hp.
              • octanehuffer
                • 5265
                The purpose of the turbo build is the ratio change. It is not as low geared, allowing more boost to be applied earlier. It does not add strength to a transmission
                  Right on, I let him know.
                  • Iroc-Z
                    Freeze, turkey!
                    • 4993
                    Originally posted by 94fobrah View Post
                    KABOOOM
                    2nd
                    Originally posted by xjfish
                    • octanehuffer
                      • 5265
                      Ready to build and it is going together now
                      carbon fiber W I D E band
                      8 Alto red frictions 7 Kolene steels in 3/4 clutch
                      Alto red frictions with Kolene steels in the forward drum
                      Alto red frictions in the reverse input drum
                      Alto red low/Reverse frictions
                      updated 29 element forward sprag
                      Heavy duty reaction sun shell
                      Corvette servo with .471 boost valve
                      Superior shift kit. Building stage 2
                      and several black magic mods that I will not disclose
                      New low roller
                      New paper/ rubber
                      This trans will be a serious performer
                        Nice parts list you got there, You prefer Superior over Transgo?
                        • driveline
                          • 45
                          I usually Spec Transgo for the daily driven cars when we build , But I prefer a superior kit for this type of application .
                          They have proven to be a good choice for our customers running these on the street or strip .
                          All these units of mine Adam is selling are built to handle a 500 hp + street strip car . He is building the 700 to my specs , Whoever gets these units will get one hell of a product for the $ .
                          Of course we can build you what you want/spec as well , with or without core .
                          • octanehuffer
                            • 5265
                            Thats right. I install Transgo for every standard overhaul on the 4L60, but I do not like the lack of shifting modifications. They are perfect for the daily driver. Not racing. I want positive shifts WITH excelent holding power.
                            • squeeezer
                              • May 2010
                              • 972
                              race unit ftmfw!!!!!!!!!!!!!!!!!!!
